Cleaning Electronic Throttle Body
Old Jan 26, 2022 | 03:18 PM
LR2driver's Avatar
Default Cleaning Electronic Throttle Body
This e-TB needs a cleaning and I need to manually move the e-TB plate to open/close it. Unlike older mechanical TB's, I understand that you're not supposed to manually press on the e-TB plate and move it while it's connected to the engine. Apparently, the open/close position of the butterfly gets out of sync with what the computer thinks the current state is. Other's say you can manually push it open and closed as long as you do it slowly. It's a point of disagreement across the forums.
In my case, I have this e-TB off the car and disconnected. Can I manually press open/close the e-TB plate for cleaning without any concerns? Will I break the motor gears that are normally controlled electronically?
Old Jan 26, 2022 | 04:39 PM
ThorInc's Avatar
I did without issue (carefully of course) while it was fully removed. Twice now actually. Getting it reattached with bottom retention clip is a PITA.
Old Jan 26, 2022 | 05:34 PM
flybd5's Avatar
You might be better off soaking it in some sort of parts cleaning solvent instead of moving the plate, and then drying it completely.
Old Jan 26, 2022 | 11:27 PM
p_gill's Avatar
Thor,
I gave up on the Land Rover spring loaded clamp and I switched to the Volvo clamp (a Jubilee style if that is meaningful to you).
988034
Take care
Paul
rh32
Oct 28, 2019 08:34 PM
zuke
Feb 12, 2019 10:53 PM
Broken08
Jun 28, 2015 03:29 PM
Dan7
Aug 2, 2013 07:04 PM
Prepilot_3ck
Feb 13, 2012 09:36 AM
