Fuel rail connection to fuel line
Old Nov 4, 2020 | 04:02 PM
Charles Bridges's Avatar
8th Gear
Default Fuel rail connection to fuel line
I did not release anything when i pulled the fuel rail off my LR2 volvo engine. How does it reconnect to the fuel line. I don't see any clip just the plastic opening for the rail. Thanks
Old Nov 5, 2020 | 08:54 AM
flybd5's Avatar
From what I am seeing in the service manual (and I am a bit sceptical of this), once you remove the high pressure line from the fuel rail, the line has to be replaced. It cannot be reinstalled. I suggest you call a dealer or a shop with experience in this car to find out if this is correct.
Old Nov 5, 2020 | 11:31 AM
8th Gear
That doesn't make a lot of sense
Old Nov 5, 2020 | 11:35 AM
8th Gear
regardless if that is the case, even with a new line how does it connect to fuel rail. I don't see any clip
Old Nov 5, 2020 | 02:16 PM
p_gill's Avatar
You need to search the Volvo Boards.
Land Rover didn't sell that many 3.2's
For reference the 3.2 is called a B6324S
Take a look at this link for an exploded parts view
https://www.matthewsvolvosite.com/fo...ic.php?t=88793
Don't forget that the 3.2 for Volvo and Land Rover was built in the UK at a FORD plant, same engine line for both.
There are some small difference depending on model year and application but those differences don't matter to what you are asking about.
I own a 2008 LR2 3.2 and a 2010 S80 3.2
And I use the Volvo part or Land Rover part for both (Which ever is cheaper)
Take care
Paul
Old Nov 6, 2020 | 03:38 PM
LR2driver's Avatar
Just to give us the big picture, why did you remove the fuel rail?
Old Nov 24, 2020 | 04:16 PM
8th Gear
Sorry for the late response. I was changing the FPR. all good now. I just put a $20 injector kit on and reinstalled!!
PosterNutbag
Aug 20, 2017 09:12 AM
Chadley
May 2, 2016 05:41 PM
Loose-Cannon
Sep 4, 2015 07:54 AM
fromdabigapple
Apr 3, 2006 06:20 PM
Bob
Other
Oct 30, 2005 09:36 AM
