Low Fuel Pressure Codes.
Old Apr 24, 2020 | 03:31 PM
gregbates's Avatar
4th Gear
Default Low Fuel Pressure Codes.
I have a 2014 LR2 that won't start. It turns over but won't crank. I was suspicious that it was misfiring so I replaced the spark plugs and it cranked, I was able to drive home. The next morning it did the same thing. Battery seems to be good but kind of like not getting fuel. I bought an OBD II scanner and got codes P008A Low fuel pressure, P0461 Fuel Level Sensor A, P2066 Fuel Level Sensor B, and P0026 Intake valve Control Solenoid Circuit. It has gas. Any ideas what this could be, did all the sensors go bad?
Old Apr 24, 2020 | 04:35 PM
flybd5's Avatar
This reminds me of what happens when some is pissed off at you and puts an egg in the tank. It almost sounds as something is mucking up the works inside the tank.
Old Apr 26, 2020 | 07:15 AM
gregbates's Avatar
4th Gear
I was literally driving it all day. I'm wondering if I got some bad gas. But, I don't understand why putting in new spark plugs would let it start and allow me to drive and then not work again the next morning.
Old Apr 26, 2020 | 10:08 AM
ThorInc's Avatar
What was the gauge level when the issue started? Fuel delivery/pressure issue maybe?
Old Apr 26, 2020 | 10:16 AM
gregbates's Avatar
4th Gear
3/4 of a tank. I'm starting to lean towards fuel sender/pump, but it's just a year old.
m1rc
LR2
51
Sep 6, 2022 06:23 PM
redrover75
Aug 28, 2022 07:03 PM
Freedom38
Jul 12, 2016 10:40 PM
Jabez
Apr 7, 2016 06:30 AM
joshlem
Apr 8, 2013 07:03 PM
