Low Fuel Pressure Codes.
I have a 2014 LR2 that won't start. It turns over but won't crank. I was suspicious that it was misfiring so I replaced the spark plugs and it cranked, I was able to drive home. The next morning it did the same thing. Battery seems to be good but kind of like not getting fuel. I bought an OBD II scanner and got codes P008A Low fuel pressure, P0461 Fuel Level Sensor A, P2066 Fuel Level Sensor B, and P0026 Intake valve Control Solenoid Circuit. It has gas. Any ideas what this could be, did all the sensors go bad?
It almost sounds as something is mucking up the works inside the tank.
I was literally driving it all day. I'm wondering if I got some bad gas. But, I don't understand why putting in new spark plugs would let it start and allow me to drive and then not work again the next morning.
