LR2 alternator replaced now won’t run
Old Jan 27, 2020 | 10:02 PM
Connor Kauffman's Avatar
Default LR2 alternator replaced now won’t run
I recently replaced the alternator on a LR2, had to pull the intake manifold. I got new gaskets and cleaned the head.
Now when I start it sputters and dies at idle. Almost like it has a vacuum leak. Is there a way to check this or check what sensor might not be reading right?
Any help is appreciated
Old Jan 28, 2020 | 07:42 AM
flybd5's Avatar
If there is a check engine light the computer will tell you.
Old Feb 10, 2020 | 10:53 AM
wardpower's Avatar
5th Gear
It isn't 100%, but you can try spraying carb cleaner around the intake seal areas while someone else tries to start it.
crackofnoon
LR2
Apr 14, 2019 11:58 PM
Puddin
LR2
Nov 21, 2018 06:12 PM
Itrujillo
LR2
Jun 15, 2018 07:12 AM
sailorcolin
LR2
Dec 13, 2014 01:50 PM
ninjaff21
LR2
Jun 4, 2014 11:59 AM
