LR2 evaporator drain hose location
Old Sep 18, 2013 | 09:42 PM
wardpower's Avatar
5th Gear
Default LR2 evaporator drain hose location
Hello All
I've got a 2008 LR2 that smells like nasty mold when i turn the A/C on. I assume the evaporator isn't draining. I was just doing an oil change and spent the better part of an hour underneath it trying to find the location of the drain tubes with no luck. Can anybody help me with a specific description or diagram? It would be much appreciated.
Old Sep 22, 2013 | 09:22 PM
roverguy7's Avatar
I don't know, as I have never had to touch one, not had a problem. I would start by changing out your cabin air filter, and there are products that will foam up the air box and remove any mold.
Also, as strange as this sounds, there is a software update for this vehicle to take care of this issue. It may help, but if there is any mold in there, I would suggest having it 'cleaned' along with the software update to prevent future issues.
Old Oct 17, 2013 | 04:53 PM
wardpower's Avatar
5th Gear
It's not the cabin air filter and the vehicle has the software updates, just trying to locate the drain tubes. Is anyone able to help?
Old May 4, 2014 | 05:22 PM
angunique's Avatar
Hello! I'm having the same issue and can't seem to find any forums about the location of the LR2 a/c drain location. Were you able to have any luck locating? If so, do you mind directing me in where they are so I can get this water drained ? Thanks in advance!
Old May 6, 2014 | 02:02 AM
LR2driver's Avatar
This thread might offer some relevant guidance:
LR 2 AC Drain Line - Land Rover Forums : Land Rover and Range Rover Forum
Old May 9, 2019 | 08:17 PM
TirasDrakkar's Avatar
Default I found the drain hose!
I found the drain hose! Sitting in the passenger seat at your left ankle there is a panel in mine only had one screw in it holding it on. Take the screw out and see A flexible tube that goes down behind the carpet. Pull the carpet back and you’ll see where it connects. Have your hose from your vacuum down in there when you pull that hose off because all the water will come out that has been collecting in the evaporator. Vacuum out both the flex hose and where the hose connects to and you should be good to go.
Old Jan 30, 2020 | 11:52 PM
Remogul's Avatar
3rd Gear
Default 2008 Land Rover lr2
A late post this evening. I just bought a 08 model and having same issue. I look for a recall on this common issue, but no luck I will try and locate that hose . My driver side floor carpet soak and wet and not using AC???? Could there be another problem?
Thanks
Justin Ruiz
LR2
Jul 16, 2021 07:03 AM
Samlc25
LR2
Apr 13, 2015 06:40 AM
phil29
LR2
Oct 4, 2014 02:00 PM
angunique
May 4, 2014 05:26 PM
chopdeere
LR2
Aug 22, 2012 10:23 PM
