Lr2 hse window issues!!!
Old Feb 9, 2021 | 10:46 AM
Tsteketee's Avatar
Default Lr2 hse window issues!!!
Hello,
I have a 2008 LR2. I love it! I never had a issue up until a couple days ago when my passenger window as well as my driver side back window won’t roll back up. It makes a noise for a brief moment like it wants to go up but then it goes quiet and nothing happens or it will start to go up then it just falls back down. I’ve read forums on here about windows but they don’t sound quite like the same problem. Is it unlikely for 2 switches to go out at the same time? I’m super frustrated. I live in MI and it’s 7 degrees. Putting plastic up doesn’t do much so I really want to get this figured out. Please, any help would be appreciated. Thank you!
Old Feb 9, 2021 | 02:46 PM
flybd5's Avatar
Originally Posted by Tsteketee
Hello,
Have you connected it an OBDII reader to see if they are any related codes being reported by the modules?
Old Feb 9, 2021 | 10:01 PM
Tsteketee's Avatar
I thought those only worked if your check engine light is on. I do have one. I can try to see if it reads anything.
Old Feb 9, 2021 | 10:10 PM
flybd5's Avatar
There are many conditions that will not illuminate the check engine light. The windows are one of them, because they are not part of the engine.
Old Feb 10, 2021 | 08:02 AM
ThorInc's Avatar
Also, check out Freel2.com and do a search on your issue. LR2 = FL2(Freelander2)
Old Feb 10, 2021 | 10:48 AM
LR2driver's Avatar
Exactly. Typically the only conditions that trigger the CEL are emissions-related or something extremely serious. Common OBD2 scanners won't read codes from all the other modules. You'll need a more advanced (expensive) reader to access those.
Your local auto parts store may offer free scans and they might have a scanner that reads all codes from all modules from all vehicle brands.
Old Feb 14, 2021 | 06:32 AM
guy's Avatar
guy
Both windows? Weatherstripping causing too much friction? Have the windows been worked on? Why are the windows down in the winter?
Old Feb 14, 2021 | 09:08 AM
flybd5's Avatar
How is this relevant to the question from the OP?
Old Feb 15, 2021 | 07:30 AM
guy's Avatar
guy
apologies... I don’t understand what seems to be opposing statements “won’t roll back up” then “falls back down”.
It doesn't sound like a switch issue to me.
Old Feb 15, 2021 | 08:36 AM
flybd5's Avatar
It appears she attempted to bring the window up manually and it would not stay up. I suspect that the window has disengaged itself from the motor, or else the motor gave up the ghost and is turning freely. But I wanted to see if there are codes first about this in the computer that might help.
Phil Nash
LR2
Nov 28, 2020 05:21 PM
BitLoud
LR2
Jul 24, 2020 08:00 PM
flyer08
LR2
Nov 25, 2019 03:25 AM
Jazon Gehrken
LR2
Dec 17, 2018 07:04 AM
roverreitzel7
LR2
Feb 27, 2013 08:29 AM
