LR2 MAP sensor location
Old Jul 26, 2023 | 06:45 PM
  #21
flybd5's Avatar
Search Google for "land rover lr2 maf connector".
Old Aug 28, 2024 | 12:34 AM
  #22
Clark2972's Avatar
7th Gear
Default Map sensor code
My land rover has a map sensor code was running fine then died and won't start just turns over I her has to the injectors and everything only code it gives is a map sensor code will this cause my vehicle to not start. Should I replace it.
Old Aug 28, 2024 | 10:30 AM
  #23
flybd5's Avatar
What code number are you getting.
Old Aug 28, 2024 | 11:21 AM
  #24
Clark2972's Avatar
7th Gear
Error code p0069 control unit: engine control unit
Map sensor baro sensor high input
Error code p0108 control unit: engine control unit
Map baro sensor correlation
When started rough start chugged then died and won't start now. it has fuel pressure up to fuel rail. Will the upper codes cause it to not start.
Old Aug 28, 2024 | 08:01 PM
  #25
flybd5's Avatar
P0069 seems to suggest your vehicle is a turbo charged model? I have no experience with those, but you might just have a bad MAP sensor, and they are not expensive to replace.
Old Aug 29, 2024 | 12:16 AM
  #26
Clark2972's Avatar
7th Gear
It's not a turbo it's a regular Volvo 3.2 straight six fuel injected
Made by fo mo co which is Ford motor company.
Old Aug 29, 2024 | 08:36 AM
  #27
flybd5's Avatar
Replace the MAP sensor. If that doesn't fix it you need a proper code reader like the Autel AP200 with the Land Rover software. $59 on Amazon.
Old Aug 29, 2024 | 08:48 AM
  #28
ThorInc's Avatar
So the locking clip on the MAP can break over time. R and R the MAP is a good plan and also make sure the MAP is seated. A drop of silicone on the two mating serfaces can aid if the clip is broken.
Old Aug 29, 2024 | 08:49 AM
  #29
flybd5's Avatar
Silicone lubricant or silicone glue?
Old Aug 29, 2024 | 08:51 AM
  #30
ThorInc's Avatar
Sealant
