LR2 MAP sensor location
Old Aug 29, 2024 | 12:03 PM
  #31
Clark2972's Avatar
7th Gear
New update took the ignition coil off and tested the ignition coil with a tester and it didn't fire so it there a ignition control module or is it all incorporated with the PCM
Old Aug 29, 2024 | 04:44 PM
  #32
Clark2972's Avatar
7th Gear
Update figured it out there was a fuse that was blown but didn't look blown replaced it and then started right up. Thank you for all the knowledge and help.
Old Aug 29, 2024 | 06:45 PM
  #33
LR2driver's Avatar
To help others out with a similar problem in the future, what was the fuse # and which fuse block?
Old Aug 29, 2024 | 07:49 PM
  #34
flybd5's Avatar
Always good news when it's an easy fix.
Old Mar 25, 2025 | 01:33 PM
  #35
wardpower's Avatar
5th Gear
Thinking the same thing... Dealing with a similar issue and would like to rule out a fuse
kind16
LR2
Sep 15, 2019 01:00 PM
jeansonnelaw@yahoo.com
LR2
Mar 18, 2016 01:51 PM
drzjoint
LR2
May 21, 2009 07:04 AM
ronx
Other
May 15, 2007 11:08 AM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
