LR2 MAP sensor location
My land rover has a map sensor code was running fine then died and won't start just turns over I her has to the injectors and everything only code it gives is a map sensor code will this cause my vehicle to not start. Should I replace it.
What code number are you getting.
Error code p0069 control unit: engine control unit
Map sensor baro sensor high input
Error code p0108 control unit: engine control unit
Map baro sensor correlation
When started rough start chugged then died and won't start now. it has fuel pressure up to fuel rail. Will the upper codes cause it to not start.
Replace the MAP sensor. If that doesn't fix it you need a proper code reader like the Autel AP200 with the Land Rover software. $59 on Amazon.
