LR2 No crank
Old Oct 29, 2021 | 10:06 PM
  #51
flybd5's Avatar
Originally Posted by UP49802
Finally... It appears that my new Mongoose Cable will POSSIBLY arrive tomorrow. I DID order a extra cable if anyone is looking for one. At the time there was nothing available that I could find in the States.
I don't think anyone sells them in the states...
Old Oct 29, 2021 | 10:48 PM
  #52
UP49802's Avatar
That would explain that then. Ill figure out where to advertise the extra one I ordered then.
Old Oct 29, 2021 | 10:51 PM
  #53
flybd5's Avatar
The classifieds section of the forum here is a good place to start. Also, that cable works with Jaguar vehicles as well, so find a forum for that with a classified section and there's your next target.
Old Oct 29, 2021 | 10:54 PM
  #54
UP49802's Avatar
Yes was just looking at that (both points). It just made sense to get a 2nd cable considering the wait time/shipping costs. I also wanted to say thank you again!! To all that helped me out. Cant wait to drive the Rover again.
Old Oct 30, 2021 | 10:50 AM
  #55
flybd5's Avatar
I think the OP on this thread:
https://landroverforums.com/forum/lr...mirror-108923/
..might want to buy that 2nd Mongoose from you.
Old Oct 30, 2021 | 12:44 PM
  #56
UP49802's Avatar
Ok... Ill send him a PM. I will only have one extra but there is more on the way. The international shipping has improved slightly but still 25 days (roughly) unless you spend for express and thats still not 100%.
Old Oct 30, 2021 | 04:01 PM
  #57
p_gill's Avatar
Look at this thread it shows lots of the areas of concern
https://www.freel2.com/forum/topic37432.html
Note: the owner with the no start problem in that thread solved the problem by re-flashing the CCF. It is possible that the non-factory communication tools corrupted the CCF.
Don't forget to try starting in neutral, I don't think you listed that.
Paul
Old Oct 30, 2021 | 04:08 PM
  #58
flybd5's Avatar
Paul
I would venture to guess that it was not the GAP tool that caused the problem, but the long time without power when the battery was removed.
Old Nov 1, 2021 | 02:34 PM
  #59
LR2driver's Avatar
Interesting idea. The data on flash memory should be persisent without power. But it might have gotten corrupted if there was an environmental stress ... temperature, etc.
Old Nov 1, 2021 | 03:24 PM
  #60
flybd5's Avatar
That is not really the case. There are two kinds of persistent memory, one is the ECU programming that is not supposed to change unless you specifically reprogram the unit, the other is data that is relevant to day to day operation. The ECU programming is in EEPROM, but the that kind of memory is relatively slower. The day to day data is usually in battery-backed persistent memory. If the battery power goes away eventually that memory loses its data.
