LR2 No crank
Old Nov 1, 2021 | 03:29 PM
  #61
LR2driver's Avatar
Originally Posted by flybd5
That is not really the case. There are two kinds of persistent memory, one is the ECU programming that is not supposed to change unless you specifically reprogram the unit, the other is data that is relevant to day to day operation. The ECU programming is in EEPROM, but the that kind of memory is relatively slower. The day to day data is usually in battery-backed persistent memory. If the battery power goes away eventually that memory loses its data.
That makes sense, you are much more precise than I was! I would have thought that anything related to the starting config would be in the less volatile memory.
Old Nov 1, 2021 | 03:54 PM
  #62
flybd5's Avatar
Well, no, that's why when you disconnect the battery the ECU has to relearn your driving profile but not the programming for engine control.
Old Nov 3, 2021 | 05:36 PM
  #63
UP49802's Avatar
So wheere is the best place tp purchase/download a month subscription for JLR SDD V160?
Old Nov 3, 2021 | 05:56 PM
  #64
flybd5's Avatar
Search the forum for the download link.
Old Nov 3, 2021 | 07:26 PM
  #65
UP49802's Avatar
I dont see it anyplace. I found a flow chart that says V130 is good for 2005 - 2012. Is that what I am looking for or?
Old Nov 4, 2021 | 03:10 AM
  #66
ThorInc's Avatar
Review this thread->
https://landroverforums.com/forum/lr...-issue-105257/
Old Nov 4, 2021 | 09:14 AM
  #67
flybd5's Avatar
It will work, SDD hasn't been updated for older models in a long time.
Old Nov 6, 2021 | 09:10 PM
  #68
UP49802's Avatar
Hello All, So after scanning today with the SDD it pointed to start control unit 100%. Is this 100% solid correct? I wasnt able to perform the LIN test as recommended. Is that needed or should I post the DTC's?
Old Nov 6, 2021 | 09:16 PM
  #69
flybd5's Avatar
Post the DTC's. There's a bunch of error codes associated with the Start Control Unit. Be careful working with that. To remove it you have to remove the airbag, and you also need to use SDD to upload the data from the existing unit to reprogram a replacement unit.
Old Nov 6, 2021 | 09:24 PM
  #70
UP49802's Avatar
OK here we go.... I guess the reason I question it is the fact that I still have the flashing alarm led with the FOB engaged. Does the immoblizer give the same symptoms? I am searching for this specific symptom but...
File Type: pdf
