LR2 Rear Differential Repair - for impacted owners
Old Mar 4, 2016 | 07:43 AM
oliver1071's Avatar
Originally Posted by LR2driver
This might help. Here is a link to a post I made showing my original diff. You could compare with your current one to see if there are any differences, but not sure how different the replacement unit looks.
https://landroverforums.com/forum/lr...43/#post440298
I just noticed that my pics where on my old isp showing the new rear. I'll have to upload them again somewhere. It's pretty easy to see the difference the new differential is held together by studs instead of bolts. Hopefully that's standard so that you can easily tell.
Oh and If you're approaching 90k throw a torx driver in your car for the steering column lock that will fail on you soon leaving you stranded. It's just two bolts under the column to remove the cover then you can give it a couple whacks with something to free it up. Should get you home.
Here are pics of the new rear and steering lock.
Attached Thumbnails LR2 Rear Differential Repair - for impacted owners-img_3353.png   LR2 Rear Differential Repair - for impacted owners-img_3354.png
Old Mar 4, 2016 | 07:15 PM
lutk87's Avatar
3rd Gear
Hi Oliver,
Do you have any experience with Haldex failure?
Thanks!
Old Mar 5, 2016 | 07:06 AM
oliver1071's Avatar
Originally Posted by lutk87
Hi Oliver,
Thanks!
I do not. I didn't even realize that the LR2 had a Haldex system. I'm used to changing the fluid and filter in a Haldex ever 10-20k miles on my old Audi. I've only looked into things on the LR2 that have failed. Battery, Fan, Rear, Steering lock and adding the trailer hitch module.
Old Mar 9, 2016 | 01:21 PM
samfb24's Avatar
Awesome, thanks for the info and the heads up on the steering column lock. I'll be doing getting in there and taking a look around this weekend.
oliver1071
LR2
22
Oct 16, 2019 08:18 PM
LR2 Tommy
LR2
Jul 10, 2014 12:54 AM
GoodLife23
LR2
Feb 16, 2013 12:08 AM
chopdeere
LR2
Aug 22, 2012 10:23 PM
shelbymustangdan
LR2
Mar 7, 2011 06:57 PM
