LR2 upper top coolant hose replacement
thanks a lot , the intake manifold gaskets were replaced less than 2 months ago , can I re-use them ?
While you are changing that one hose, you should also replace the thermostat if you haven't done so in a while, and check all the other hoses as well.
always appreciating your constant support , thank you very much .
