no crank, no obd but hazard flasher
Old Nov 4, 2023 | 10:19 AM
  #31
flybd5's Avatar
Originally Posted by OldKarz
Probably can't reset since he cannot chat to the modules. There is a common thread in all the faults shown - short to ground or open ground. there are more faults that are not shown which may help narrow down the common grounding issue.
Still, worth a try.
Old Nov 4, 2023 | 10:39 AM
  #32
botswanabub's Avatar
Originally Posted by flybd5
Still, worth a try.
dont unterstand? I added the output.
now I tried to understand the BUS analog ... means measurement with a multimeter.
results:
resistance HS CAN: 60Ohm
resistance MS CAN: 1,8MOhm
HS CAN H: 2.3-2.4V
HS CAN L: 2.5-2.6V
MS CAN H: 2,3V
MS CAN L: 2,9V
for me it looks like the MS CAN is the problem? but why cant connect to RCM?
this all doesn't make sense
Old Nov 4, 2023 | 10:45 AM
  #33
flybd5's Avatar
results:
HS CAN H: 2.3-2.4V
HS CAN L: 2.5-2.6V
MS CAN H: 2,3V
MS CAN L: 2,9V
The reality is that you don't know what those resistance are going through. And you don't have reference values. Guessing will not help you.
Old Nov 4, 2023 | 11:01 AM
  #34
well CAN bus normaly must be 60Ohm ... means two 120ohm parallel.
Old Nov 4, 2023 | 12:02 PM
  #35
OldKarz's Avatar
No. Two 120's in parallel should read 60 ohms not 600. So both readings are incorrect. Did you disconnect the battery while taking the readings? The bus voltage can affect the resistance readings. While disconnected check the resistance of each line to ground. They should all be grater than 10k ohms.
Old Nov 4, 2023 | 12:26 PM
  #36
@OldKarz 60 Ohm ... not 600 ... 600hm doenst make sense
but no, batt was not disconnected.
I checked the wiring diagram and disconected the AC control as gateway for the MS CAN. With this the dashboard and other devices aren't working, for me means the MS CAN could be OK.
Altus Bylsma
Apr 13, 2020 11:26 AM
int64
LR4
Aug 11, 2019 06:30 AM
stevey88
Feb 14, 2009 10:45 AM
lrd99
Jun 29, 2007 06:38 PM
