Outside air sensor
Old Feb 25, 2016 | 07:26 PM
bosalls5's Avatar
Default Outside air sensor
2009 LR2 HSE Land Rover (120,K). Outside air on the dash reads 145 deg after driving an hour (50 miles). Car runs and drives normally, no fault codes on the dash. When standing still temperature drops to 130 deg. Bad sensor or what is causing the high temperature near the sensor? Coolant is at a normal level, nothing appears to be leaking. What do you think?
Bob A
Old Mar 5, 2016 | 03:48 PM
welder403's Avatar
Could be the PCM or loose/bad sensor
KlamathMatt
Apr 17, 2020 05:27 AM
bosalls5
Feb 25, 2016 07:19 PM
Bishop
34
Oct 29, 2014 01:27 PM
rkrainak
Oct 11, 2007 09:15 PM
