Rear catalytic converter leak
Old Jan 17, 2020 | 07:57 AM
flybd5's Avatar
Default Rear catalytic converter leak
I've got a leak somewhere in one of the flexipipes between the front and rear catalytic converters. There are no codes at the moment, just noise. Can flexipipe be replaced, repaired or patched, or should I replace the entire assembly?
LR2 rear catalytic converter
Old Jan 28, 2020 | 11:24 AM
flybd5's Avatar
If you need to replace one of these (don't bother looking at YouTube videos on how to fix flexible pipes, it won't work on the LR2) the best place I found is this one:
https://mufflerexpress.com/products/...ytic-converter
Quick shipping, excellent customer service and the price is about 1/3 of what you will pay on eBay and 1/5th of the dealer price. Note that if you buy this you will need your own rear gasket, bolts and nuts. If the front gaskets cannot be reused you'll need those too, but those run about $200 for a pair.
zracin
Jan 23, 2024 10:19 AM
djkronik57
Mar 29, 2017 10:22 PM
Racer X
ROAMING WITH FRIENDS
May 12, 2013 08:25 PM
Rovermike85
Feb 9, 2012 07:36 PM
SUMOSINO
Feb 9, 2006 10:04 AM
