Terrain Response System no power
Old Oct 19, 2024 | 12:10 AM
LR2driver's Avatar
Try TSB #LTB00478NAS2 (attached).
I would have saved myself a lot of time and money if I made a habit of checking TSB's as an early step in troubleshooting. I'm a late learner.
File Type: pdf
Old Oct 20, 2024 | 05:23 AM
mikemedic3's Avatar
Thank you for answering I really appreciate what you do on here was hoping to find someone that has seen this, and solved it, if when I figure it out I will post for others.Have a great weekend.
Old Oct 23, 2024 | 06:30 AM
mikemedic3's Avatar
I agree but this happened after I pulled the coupler changed oil, filter and replaced, so it seemed to me to be that something didn't like being touched, wire loom intact, but did notice a "crunchy" ground strap over the diff with part of the woven part separated, so I was questioning whether or not I was losing ground with movement of the strap. I'll look into the tsb some more but reeeeeally trying to avoid stealership, All the work I just did tires, tie rod end, alignment, fluids, filters just smoked the daughter's savings and that not the 150-labor charge. I gave her this vehicle after school ended because I am retired now and just share a car with the wife, so this is not a ride I would normally recommend for her, or anybody.
Old Oct 26, 2024 | 09:07 AM
mikemedic3's Avatar
anyone know where G4d149-1 and g4d149c-1 ground from coupler boardlocation is terminated location so I can check for rusty, connection, in RI it's basically all that's left on this thing.
thank you
Last edited by mikemedic3; Oct 26, 2024 at 09:08 AM. Reason: forot to put ground and coupler control board
Old Oct 26, 2024 | 10:16 AM
ThorInc's Avatar
https://www.freel2.com/gallery/displ...413&fullsize=1
Old Oct 27, 2024 | 06:17 AM
mikemedic3's Avatar
Thank you so much I really appreciate the help and this community.
Iskion1
Apr 26, 2025 10:06 AM
Landlarry26!
LR2
Jul 16, 2021 09:28 PM
09dewaed
Jun 15, 2018 11:00 AM
m1rc
LR2
Dec 24, 2015 02:47 PM
Rover_Hokie
Apr 5, 2014 11:09 AM
