05 LR3 Fuel Door Actuator
Old Apr 23, 2012 | 10:22 AM
mgnyc's Avatar
Default Needed to replace bezel and actuator plunger
Had the same problem and finally determined that both the fuel door actuator plunger (part number BPA780101G) and the bezel had to be replaced. The old actuator (small tooth had broken off) had to be pulled out with needle noze pliers but the new one fairly easily snapped in. Watch for spring that falls out when the actuator is removed - needs to go in before new plunger inserted. However the new actuator didn't catch old bezel on the fuel door even though that part didn't seem damaged. Replaced the old bezel and now works. All parts from atlanticbritish.com (with astute mechanical advice from brother-in-law).
expedio2005
Oct 4, 2019 01:57 PM
vic_lagina
Aug 6, 2015 06:54 AM
airmarc
Jan 11, 2012 12:01 PM
