'06 LR3 Electrical issues
Old Jul 19, 2017 | 10:46 AM
  #21
bbyer's Avatar
Default Land Rover does this for free?
Originally Posted by abran
Autologic. You actually download the software profile for the vehicle ICM(cluster), then upload the request to Land Rover for the software. Once Land Rover sends it back you use that file to update/sync the cluster.
Somehow I doubt that Land Rover does this for free?
It is good to know that there is at least a procedure.
Now is that with a brand new Land Rover supplied instrument cluster, or a junk yard unit?
Old Jul 19, 2017 | 02:28 PM
  #22
abran's Avatar
$1500 a year for software subscription.
You can only do this with new, genuine cluster. As is the case with almost all the modules on the 3.
Old Jul 20, 2017 | 08:07 AM
  #23
LRDave3's Avatar
7th Gear
I have removed the dashboard components and removed the cluster (Thanks to an informative youtube video), unplugged it and plugged it back in with no better results.
The Instrument cluster store in N. Pennsylvania uses junk yard clusters hence the $450 price instead of $1100+/-. 90 Day warranty, however I need to read the small print carefully.
Old Jul 20, 2017 | 08:51 AM
  #24
abran's Avatar
Can you share this cluster store's details? I'm interested in testing one to see if it works. Thank you
Old Jul 20, 2017 | 11:19 PM
  #25
bbyer's Avatar
Default You Tube link?
[QUOTE=LRDave3;613125]I have removed the dashboard components and removed the cluster (Thanks to an informative youtube video), unplugged it and plugged it back in with no better results.]
I wondered if your cable seemed to have lots of slack in it or was it sort of tight?
I noted that per that second link in my post post, the poster had to straighten some of the pins in the socket to get his cluster to work.
Would you post the You Tube link to the How to Remove the Cluster.
Old Jul 21, 2017 | 07:58 AM
  #26
LRDave3's Avatar
7th Gear
I watched that video and did the removal and replacement about 10 months ago. I don't remember how I came across it but you just have to put in key works and search through You tube. If I recall, it wasn't even an LR3, it might have been a discovery, but I figured it out from there. You have to lower the steering column all the way to access. the cluster.
Old Jul 21, 2017 | 08:01 AM
  #27
LRDave3's Avatar
7th Gear
The store in Northern PA is called "The Instrument Cluster Store". Google the name with ",PA" and you'll find it.
Old Jul 21, 2017 | 09:32 AM
  #28
abran's Avatar
thanks!
nh9095
Jan 14, 2019 12:36 AM
mikest75
Feb 6, 2014 06:35 PM
95raingerowver
Feb 19, 2008 07:28 AM
dustin309685
Nov 18, 2006 07:45 PM
russ00001
Aug 6, 2006 03:54 PM
