06 lr3 r/f door lock actuator relacement
Old May 8, 2018 | 09:28 AM
jacburke's Avatar
5th Gear
Default 06 lr3 r/f door lock actuator relacement
I get to the point where the support plate for the window motor is loose but cannot get it free enough to access the actuator...have viewed several tutorials and it seems as though I'm missing either a certain clip(s) removal or a particular part of the procedure itself. Thank you in advance for any help.
Jac
Old May 8, 2018 | 10:12 AM
abran's Avatar
You need to unclip the 2 white clips that are attached to the window.
then angle it and remove, it’s a bit of a struggle.
once you get to the handle there is a torx on the back side that screws into a t that holds the handle on.
i suggest removing handle and actuator as one.
Old May 9, 2018 | 05:12 AM
jacburke's Avatar
5th Gear
Abran !
THANK YOU THANK YOU THANK YOU ! I'm going to try this again today, but with a renewed sense of confidence due to your response !
Jac
Old May 9, 2018 | 08:13 AM
abran's Avatar
Welcome, welcome, welcome!
good luck.
Old May 9, 2018 | 06:06 PM
jacburke's Avatar
5th Gear
Mission accomplished ! Did both right side doors. You were spot on....took a little wiggleation and determination ! Thanks again Abran !
Jac
Old Jun 20, 2018 | 10:38 PM
StephanStevieK's Avatar
What is the best way to unclip the two clips? I cannot reach the furthest clip through the speaker hole regardless of what position the window is in.
Old Jul 20, 2018 | 09:05 AM
jacburke's Avatar
5th Gear
please forgive my very late reply...(health issues...I'm doing quite well now). I used a flexible shaft "dental" type mirror to view the clip. It gave me the visual perspective I needed to eventually access it. I must admit, however, for me it was quite the task. Persevere !....and Good Luck to you !
Jessietaz87
Jun 8, 2018 09:49 PM
FRLNDR
Freelander
Jan 13, 2016 04:25 PM
redwhitekat
Dec 14, 2013 08:17 PM
muddybuddy
Jul 15, 2009 11:00 PM
