2005 LR3 - doesn't start now?? Advice needed
Old Sep 10, 2013 | 06:16 PM
Vantablian's Avatar
Default 2005 LR3 - doesn't start now?? Advice needed
Hello -
Over the last week or two there were a couple of times where I went to start the vehicle and it didn't click over - and then of course the engine light comes on, etc... A few times the issue just "disapeared" and it was turning on just fine. One other time I opened the fuse box and took out and put back in one of the bigger fuses that had the engine symbol on it, and it started just fine after that.
Now, I can't get it to click over - and tried jumper cables and it wouldn't work. It's a little frustrating because it seems like it's a "computer" thing, or the fact that maybe I just need to replace the fuse? It doesn't seem like it's the battery because it's only 7 months old - I just don't get it, I will take any advice or measures I can try to get it back to working order.
Thank you
Old Sep 10, 2013 | 08:51 PM
If you have a voltmeter, which run $5 - $20, you can measure the battery volts, and turn on the head lights (if they come on) and see if volts drop a bunch. A "new" battery can have a loose connection, a dirty ground connection, or a dead cell. You can also do a continuity test on fuses, there could be a hairline crack. Hold hood alarm switch down while you are doing all this for good luck.
Old Sep 10, 2013 | 09:38 PM
roverguy7's Avatar
What do you mean by 'click over'?
Is it cranking, but not starting up, or not cranking at all? Do you hear a loud click when you try and start it?
Most common issues with these(assuming V8) not cranking is a failing starter solenoid, or weak battery.
Old Sep 10, 2013 | 10:05 PM
Rover2013's Avatar
Yeah rover guy is on to something there. But it is a 2005 is there anything else going on water in the floor boards on passenger side
Does it not start after it rains.
EHGIII
Mar 17, 2015 10:33 AM
Zahird
Jan 10, 2015 02:54 AM
Vantablian
Jul 8, 2013 10:53 AM
dmatranga
Feb 5, 2013 12:27 AM
Evan Wiley
Dec 31, 2012 03:43 PM
