2005 Lr3 won't start
Old Jul 21, 2015 | 03:21 AM
Chico82's Avatar
3rd Gear
Default 2005 Lr3 won't start
Hello everyone,
I have an Lr3 and it's giving he a hard time starting up. It took me 3 hours to get her going the other night. Thinking it was the battery I had it tested and came back being a good battery. When I turn the ignition I get the 2 clicks and it sounds like it's coming from the glove compartment. I am leaning more towards the starter going bad. Any suggestions before I take it back to the dealer and try to get it fit by them. Thanks..
Old Jul 21, 2015 | 05:51 AM
Ghaniba's Avatar
That would be my guess. Before I did any real work, I'd check the connections on the battery, verify they're tight AND clean. Look for corrosion on the cable itself. I've not heard of the LR3s doing this, but the D2 suffered it a bit on the positive cable running down to the starter.
Your post is timely, if you end up doing it yourself, someone recently did a writeup on it!
https://landroverforums.com/forum/lr...acement-46945/
Dave
Old Jul 21, 2015 | 06:41 AM
Chico82's Avatar
3rd Gear
Dave
Thanks for the help. Seems like a timely job. But might take on the challenge. .
Old Jul 27, 2015 | 03:41 PM
Chico82's Avatar
3rd Gear
Default Lr3 won't start
Update. It ended up needing a new starter..
larrysaccone
Aug 25, 2025 05:01 AM
averagejoe
Oct 25, 2013 02:08 PM
nic1641
Sep 6, 2011 11:13 PM
pittsburghrover
Jul 13, 2011 03:29 PM
Joentuff
Mar 14, 2011 10:02 PM
