2006 LR3 cuts out when I press the brake
Old Jul 9, 2023 | 09:25 PM
4bear4's Avatar
No, I have never used for towing.
Old Jul 9, 2023 | 09:26 PM
4bear4's Avatar
No, Do you feel it's worth pulling out the box behind the battery
Old Jul 9, 2023 | 09:29 PM
DakotaTravler's Avatar
I never said you used it for towing, just to inspect for the installation of the wiring for it. Cause there have been cases were old trailer harness wiring was installed poorly then cause issues. And yes, check the connections as I mentioned before. If you won't do the things we recommend, then there is no point to continue unless those things are eliminated as possibilities.
Old Jul 9, 2023 | 09:46 PM
4bear4's Avatar
OK I will check the trailer wiring (is there a reference for its location?)
I will check this and connections behind the battery tomorrow
Thank you
Old Jul 9, 2023 | 09:50 PM
P-Bod's Avatar
There are vulnerable connections behind the battery that do need to be inspected. I took these pics when I first started digging into mine. It’s not terribly difficult to check once you pull the battery.
Old Jul 9, 2023 | 09:59 PM
P-Bod's Avatar
https://www.roverparts.com/Instructi...ingKit-LR3.cfm
Here’s a good trailer wiring reference.
Old Jul 15, 2023 | 11:00 AM
4bear4's Avatar
Hi
Quick update
So I puller all the wiring including the silver box from behind the battery. disconnected , cleaned and replaced.
Checked all the fuses in the engine fuse box
Car started but immediately shut off when I applied the brake,
Now sometimes starts, sometimes nothing at all
Other times wipers/hazards etc.
Scan tool continues to state that car has lost communication.
Will look to tackle the towing harness next!
Old Jul 15, 2023 | 11:08 AM
Did you have time to pull the knee panel and inspect for a remote start system? The panel just pulled straight out from the top side. Good yank. Look all over under the steering area for anything that does not appear to be factory.
Old Jul 17, 2023 | 08:52 AM
4bear4's Avatar
Now only the radio working... everything else is non responsive!
twcord
Sep 30, 2021 08:17 AM
mrhollaway
Mar 30, 2021 05:02 PM
Athana
May 4, 2018 07:15 PM
4puf
Nov 16, 2016 02:45 PM
