2006 LR3 notchy binding steering
Old Aug 5, 2017 | 02:15 PM
tommizerek's Avatar
3rd Gear
Default 2006 LR3 notchy binding steering
Hey everyone....I have a 2006 LR3 with 116,000 miles on it my steering became very notchy, I've been told that it's probably the lower steering shaft, I cleaned and lubed the u-joint, it seems like it got a little better, but what I've realized is that the notchiness happens after driving for a while, and doesn't happen while the car is stopped and wheel is turned, ps fluid looks fine, the ps pump is not making any noises and the belt seems tight....I figured if it was the u-joint on the lower steering shaft it might get better with driving for a while, but it's the other way around....very confused....any suggestions?????
Old Aug 7, 2017 | 08:13 AM
abran's Avatar
Yes!
post in the LR3 section...
Old Aug 7, 2017 | 08:46 AM
Moved to the right forum
Old Aug 7, 2017 | 09:04 AM
houm_wa's Avatar
There is a U-Joint on the bottom of the steering column. That's usually the issue. Some people have had success lubing that...I had my steering column replaced (that section of it anyway) instead and it's been good since.
Old Aug 8, 2017 | 05:37 AM
tommizerek's Avatar
3rd Gear
Thank you....I'll try lubing it, if that works I'll get a new lower shaft and install it when it starts binding again
Old Aug 8, 2017 | 06:24 AM
Ghaniba's Avatar
Mine does the same thing, simply builds up because it sits. Got much better after driving it for a day, but I too plan to just swap it out. "Lower Steering Shaft" I believe it's called. Should be about $110 ish.
Dave aka Ghan
Old Aug 8, 2017 | 11:59 AM
DavC's Avatar
exposed U joint midways in steering input shaft, can see it from engine bay. If it gets dirt, mud, crap in it it will start binding up and get really notchy.
Sometimes you can get it to go away by dousing it in WD 40 and then smearing it with some grease. YMMV
Old Aug 8, 2017 | 02:57 PM
WNYErikDiscoII's Avatar
Former Sponsor
You need this: https://www.lucky8llc.com/products/l...column-genuine
Pretty sure we have a 10% off code floating around this week, too..............
houm_wa
Nov 20, 2014 01:47 PM
Glen11
Jun 11, 2014 08:56 AM
Mountain Goat
May 23, 2012 12:28 PM
bothomasmusic
May 24, 2011 12:47 PM
IanWhitefeather
Nov 13, 2010 05:45 PM
