Air Suspension Fault after new pump install
Old Jul 17, 2021 | 07:55 AM
  #21
Garret Plumley's Avatar
8th Gear
Maybe your center valve block solenoid is not opening when energized. Which would mean a faulty center valve block or wiring.
that could be. I replaced it last winter. I looked at all the wiring, seemed ok, but could be a bad valve block. It happened less before I changed it
Old Jul 17, 2021 | 09:34 AM
  #22
8th Gear
Originally Posted by Flyun
Yes, you've totally got it. The problem is if the center block isn't able to vent the gallery stays charged so the pressure that is in the front and the rear is now connected together with the vent closed. The system doesn't care if it is Hitachi or an external compressor as long as the system reacts the way the computer thinks it should react (not too fast, not too slow, close the right circuit, etc). Often times replacing the block doesn't change anything if the contacts are still corroded.
one more thing to add. I recently got new tires on it and for 3 days I had no faults. Could that possibly be the height sensors?
Old Jul 30, 2024 | 08:51 PM
  #23
Lmwong's Avatar
3rd Gear
Did you ever figure this out? I’m having the same issue with C1A18-64 fault coming back after replacing the compressor (AMK), servicing the center block (new O rings), and reflashing ECU. I was jazzed when the fault went away for 2 weeks but it came back! Maybe I’ll try cleaning electrical connectors or replacing the center block altogether.
Old Feb 8, 2025 | 12:11 AM
  #24
RickyN29's Avatar
I’m curious if they ever figured it out too. Now I’m dealing with the same. Really getting tired of this POS.
Old Feb 9, 2025 | 07:50 PM
  #25
Lmwong's Avatar
3rd Gear
I replaced the middle valve block RVH000046 and it fixed it.
Old Feb 12, 2025 | 05:07 PM
  #26
RickyN29's Avatar
Thanks for replying, glad to hear you fixed it!
For others searching, my middle valve was new. I found a loose wire on the presure sensor connector (again) and that fixed it.
DbDet
Aug 7, 2019 08:26 PM
Chris Talleri
Jan 31, 2019 10:08 AM
kwackwacker2
Jun 2, 2017 10:42 AM
CBRover
Apr 22, 2017 08:20 PM
VCFZ
Sep 3, 2014 10:30 AM
