Airbag Light On
Old May 16, 2018 | 04:24 PM
anothersilver's Avatar
Default Airbag Light On
The airbag light is going on intermittentaly due to the left driver door sensor. I have tried changing the sensor, the steering clock spring, and checking the door wiring harness and I don't see any issue. However the light still comes on intermittently and usually just shutting down and restarting the car will make it go away. I also get codes for a ride height sensor and loss of communication with instrument cluster. The battery is new and I have tried clearing the code many times but it still comes back. Are there any ideas on how to find the issue?
Old May 16, 2018 | 05:42 PM
abran's Avatar
So there is a code for left Driver door SRS sensor?
Old Jun 5, 2018 | 01:52 PM
yes I get code B0091 permanent, bus signal/message failure - invalid serial data received
Old Jun 5, 2018 | 02:49 PM
abran's Avatar
And you have referenced that code to some explanation that its the door?
Old Jun 6, 2018 | 06:09 PM
schwaggy's Avatar
Yeah I'm confused too. You sure the problem isn't with the seat cushion pressure sensor (NAS only) or seat cushion pressure pad (NAS only) - passenger seat?
mln01
Nov 14, 2019 07:15 AM
TestPoint
Jul 11, 2016 09:44 AM
slocalsvt
Jun 29, 2011 11:02 PM
tweakrover
Jan 25, 2011 02:42 PM
snugg
May 13, 2008 09:19 PM
