blower motor not working
Old Jun 19, 2010 | 09:07 AM
mycleo's Avatar
3rd Gear
Smile blower motor not working
hey ppl, i have a 05 lr3
I was using the AC today, parked the LR at home and left it running for a bit, When I got in, the blower had quit. I tried heat and AC and all the settings. I looked at the fuses and found that everything ok I did smell a weird smell when driving but assumed it was something that was spilled earlier, need help please
Old Jun 19, 2010 | 10:43 AM
Rovin4life's Avatar
oh I know what that is. You will need a new blower motor resistor. Do not turn it on again, look underneath the passenger side, its possible it melted the relay and the connector as well. If that is the case you will need a new harness. Not the entire body harness just the section of it.
Old Jun 19, 2010 | 11:41 AM
mycleo's Avatar
3rd Gear
Unhappy
where do i look? does any one know how to dis assemble the dash where the resistor is? can i bypass it till monday keep it on high speed, i have to make a long drive and its very humid and rain
Old Jun 19, 2010 | 03:53 PM
Rovin4life's Avatar
take a philips screwdriver and take off the screws underneath where the puddle lamp is on under the passenger side dashboard. From there you should see the resistor or something smoking.
and no don't use it. If its smoking its already beginning to melt stuff.
Old Jun 19, 2010 | 04:04 PM
mycleo's Avatar
3rd Gear
its already smoked it does not smoke anymore thans r4l
Old Sep 7, 2013 | 08:24 PM
TommyCasanova's Avatar
Default how to get to resistor?
How do you get to the resistor? it looks like you have to remove the fascia underneath the passenger side, along with everything else just to get a screwdriver to fit to remove the resistor.
Do you have contact email I can reach you directly?
tsuyoi
Sep 22, 2020 10:37 AM
calebbo
Mar 31, 2017 12:47 AM
03discoken
Mar 9, 2015 03:47 AM
james.martin1
Feb 21, 2015 05:58 PM
imnappraiser
Aug 27, 2009 12:16 PM
