Check engine light after swapping water pump
Old 10-28-2019 | 11:23 PM
Globetrotter448's Avatar
The MIL light will also come on for faulty O2 sensors or connectors. but seems more like air leak
AF-LR3 (10-29-2019)
Old 10-29-2019 | 07:57 AM
AF-LR3's Avatar
Re-reading your original post. When you cleaned the TB, did you remove it by chance? If so that may be your issues. The metal gasket is one-time use really. But ideally one using some high-temp sealant. I prefer Reinzoil. Apply a very thin film on each side of the TB gasket and the EGR gasket. I had a lean code and this took care of it.
I was thinking this as well, not a fan of metal gaskets like this. I checked all of my vacuum and air hoses, couplers, and o-rings/gaskets last night, and the TB gasket was the only thing I could think of causing it. I’ll try adding some sealant tonight. Thanks!
Old 10-29-2019 | 08:05 AM
AF-LR3's Avatar
I know right Dakota? New and interesting spam technique.
Where are you at in Georgia I have a GAP tool if you need to dig a little past the standard OBD II
Thanks for the offer! I don’t think I’ll need the GAP tool for this issue, but I do plan on purchasing one soon. I just bought the LR about a month ago, and even with the CEL on, it’s running way better than when I got it. It has a few issues that were neglected by the PO that I’m working through right now, but overall it’s solid. I’m in Canton BTW.
Old 11-07-2019 | 02:20 PM
AF-LR3's Avatar
Pulled the throttle body gasket and applied a thin layer of red rtv gasket sealant to both sides as suggested. So far, I’m over 200 miles in, and it’s running smooth with no CEL. Thanks for the help!
Athana (12-08-2022)
ljdiscovery
05-12-2019 04:48 PM
clint70
10-22-2015 09:08 PM
larson3000
03-23-2010 06:19 PM
lipadj46
07-09-2009 04:03 PM
theworks001
11-13-2008 08:19 PM
Quick Reply: Check engine light after swapping water pump
