Climate Control LEDs broken
Old Nov 28, 2021 | 01:50 AM
Rorym's Avatar
Default Climate Control LEDs broken
Hi All been searching for a few hours on here but no one seems to have the same issues I do.
Basically the climate control seems to be working fine but most of the LEDs don't work so when I hit auto it seems to switch to Auto function but the 2 lights don't go on. Then once I hit any of the defrost buttons I can hear the fans switch to max and start blowing on the screen but again none of the LEDs lights up.
The LEDs work for the heated seats and air receicrulation but that's about it.
Is this just case of buying another unit?
Thanks!
Old Nov 28, 2021 | 01:31 PM
DakotaTravler's Avatar
Odd, they are pretty robust LEDs in there. I guess a new unit would be a good idea because the HVAC panel is required for the truck to start. With it missing/damaged the truck will not fire up.
Old Nov 29, 2021 | 12:04 AM
loanrangie's Avatar
Which leds, the ones around the dial don't light up in auto mode but will if you adjust the temp either way.
Old Nov 29, 2021 | 02:36 PM
Rorym's Avatar
Yeh even when I spin the fan dial no Leds come on and also the Leds that should light up what the current temp is set to doesn't work.
Old Nov 30, 2021 | 12:48 AM
Alex J's Avatar
Do your dash lights work at night? When I first got my LR3 none of the backlights worked, even the dash backlights were dead then I found a burnt fuse and everything worked again. If the only thing that isn't working is the HVAC control stuff then you may be in need of a new panel but I'd check fuses first. Couldn't hurt to just take it out and check the harness connections on it as well.
elrocha69
Mar 30, 2020 08:06 AM
Sean Winter
Aug 26, 2017 12:14 AM
completelymobile
Feb 21, 2015 02:02 PM
Take THAT, Jeep!
Dec 13, 2013 01:40 PM
souljad9
Apr 30, 2011 10:16 AM
