Clunk, brake calipers?
I am getting a clunk at high speeds on dirt roads that seems to be coming from the front. It isn't consistent. I have noticed that if it is making the noise and I apply even the slightest pressure on the brakes the clunking stops.
The sway bar bushings and end links have been changed, all of the suspension bushings tested good. I've replaced the caliper bolts on both fronts with no difference. Anyone else experience this? Any ideas.
Thanks,
Jim
Thanks,
Jim
Pressing the brakes a little bit does a lot more then just apply the brakes, you limit suspension travel, you transfer weight to the front end, and you pre-load the axles, diff, hubs, and the rest of the drive train.
Is it only at higher speeds, or does it happen over bumps in a parking lot as well? I would be taking a look at control arm bushings and ball joints, and also double checking the torque on the sway bar links.
