Clunk, brake calipers?
Old Apr 23, 2013 | 11:00 PM
jhawk's Avatar
4th Gear
Default Clunk, brake calipers?
I am getting a clunk at high speeds on dirt roads that seems to be coming from the front. It isn't consistent. I have noticed that if it is making the noise and I apply even the slightest pressure on the brakes the clunking stops.
The sway bar bushings and end links have been changed, all of the suspension bushings tested good. I've replaced the caliper bolts on both fronts with no difference. Anyone else experience this? Any ideas.
Thanks,
Jim
Old Apr 24, 2013 | 08:50 AM
roverguy7's Avatar
Pressing the brakes a little bit does a lot more then just apply the brakes, you limit suspension travel, you transfer weight to the front end, and you pre-load the axles, diff, hubs, and the rest of the drive train.
Is it only at higher speeds, or does it happen over bumps in a parking lot as well? I would be taking a look at control arm bushings and ball joints, and also double checking the torque on the sway bar links.
Old Apr 24, 2013 | 09:07 AM
jhawk's Avatar
4th Gear
Only time I get noise is 30 mpg or more on dirt roads, and then not consistantly. Never anything in day to day driving, braking, speed bumps, etc. All of the bushings and ball joints check out good.
Jim
Old Apr 24, 2013 | 09:15 AM
roverguy7's Avatar
How loud is it, sure it's not traction control kicking in?
Old Apr 24, 2013 | 09:23 AM
slickzero76's Avatar
I also have a clunking sound coming from the front end. I notice mine going over speed bumps and ruts offroad. It makes the noise when the front end goes over but is quiet when the rear end does. I check sway bar bushings but haven't gone any further.
Old Apr 24, 2013 | 10:02 AM
roverguy7's Avatar
The most common issue with the front suspension on these trucks is the lower control arm bushings. when going 5-10mph, stab the brakes, if you hear a metalic thud, they're on the way out if nothing else.
Old Apr 24, 2013 | 10:08 AM
stmcknig's Avatar
Look for leaks on the rear front lower bushing - they're fluid filled and once the fluid escapes they need replacing. That's what resolved my clonk.
Old Apr 24, 2013 | 10:42 PM
jhawk's Avatar
4th Gear
Thanks, everyone. The lower control arm bushings are good, again no sounds when braking, over speed bumps, etc. I'm at a loss. As soon as I figure it out I'll post.
Thanks,
Jim
Sam95disco
Feb 19, 2013 08:19 AM
Cassidy Bodle
Jun 3, 2012 11:17 AM
calebbo
Jun 30, 2011 01:34 PM
welling4x4
Sep 29, 2010 11:10 AM
DiscoMike2003
Nov 13, 2008 04:57 PM
