Code P0026
Old Jun 12, 2019 | 03:37 PM
  #21
GemelRover's Avatar
The engine seized. It became so hard to turn had to manufacture a special tool to hold the crank pulley. Found two spun rod bearings that damaged the crankshaft beyond repair. I found the oil siphon/ oil intake filter completely clogged. The B109 must have loosened all the crud and grime in the engine. Couldn't believe how much crud was in there.
Now, rebuilding.
Old Jun 12, 2019 | 03:41 PM
  #22
Luc1f3r's Avatar
Now, rebuilding.
I'm sorry to hear that.
I suspected the engine being seized because I used engine flush on an old chevy lumina when i was a teenager and the same thing happened. It did such a good job loosening everything up that it killed the pump and seized the engine.
Old Jun 12, 2019 | 07:03 PM
  #23
abran's Avatar
When you say B109, Are we talking 109WOR, known as "EPR"? I have not had one issue using it on the 5.0 motors.
Old Nov 21, 2019 | 09:20 AM
  #24
GemelRover's Avatar
BG109 EPR is what I had used.
Rebuilt the engine. New bearings, new rings, valves etc. Also replaced the VVT's. It ran great for the 50 miles I drove it to the dealership to get alignment, when returned to me, it was a different car. It was sluggish and the same codes are back.
DiscoTime
Sep 17, 2019 08:35 PM
Cobra_R
Feb 14, 2017 11:18 AM
hatt53
Mar 27, 2013 05:16 PM
bamaboy473
Aug 11, 2012 05:44 PM
DeepBlueWater
Oct 20, 2011 06:27 AM
