Is (converted) coil suspension bad?
Old Sep 9, 2017 | 05:05 PM
Mads Jakob Poulsen's Avatar
5th Gear
Default Is (converted) coil suspension bad?
I Am looking to buy a used (circa 2005) LR 3 in the cheaper end of the scale (4-6k depending on condition). Several of these vehicles that I have test driven have had the air suspension converted and now have coil springs. What do you think about that?
I do not need to take this vejicle off-road.
Do you have pros/cons for the two kinds of suspension?
Any help/info very much appreciated.
Thanks!
Old Sep 9, 2017 | 05:29 PM
I own 1 of each LR3 coil sprung and air sprung. Both are great.
The Air sprung LR3 rides better period end statement. It is smoother down the road and feels better around the corners. Off road the air suspension just works so well. If you load 5 people luggage and a trailer behind it the LR3 still rides the same and level.
Downside is repairs can be super expensive especially if you don't do your own work. Trouble shooting it requires a tool like the GAP IID tool which is more money. The system is robust and reliable if maintained.
Coil sprung rides good, it handles good as well. It does well off road as long as you have a proper conversion that keeps the terrain response system intact. Nothing really to break. No faults no issues just reliable old coil springs.
No increased load handling, through a winch bumper or a trailer on it and use loose height on the suspension. 5 people and luggage it will be squatting down just a fact of coil springs.
In the end owning and driving both, the air suspension is superior both on and off road. Is there anything wrong with the coil sprung, not at all it's just not as good.
Old Sep 9, 2017 | 05:58 PM
5th Gear
Thank you for that run down. Veey helpful!
Additional question: If you dont do your own work and the suspension fails, either airbag or coil.
Do you have a rough ballpark estimate of price for parts+labour to fix it?
i have seen numbers ranging from less than 1k to 7k(airbag) and it seems like a faulty suspension is one of the biggest/mist common risks when buying a used LR3. Almost all I have test drives has had more or less of a faultt suspension.
Thanks.
Old Sep 9, 2017 | 06:11 PM
labor rates will depend based on you location and if you go to a dealer to independent.
pair of front air struts
https://www.lucky8llc.com/collection...t-shock-set-x2
new compressor
https://www.lucky8llc.com/collection...air-compressor
there are more bits like the valve block etc but those are the 2 major items
If you are not mechanically inclined or new to Rovers I would recommend a pre-purchase inspection by reputable shop or dealer.
Old Sep 9, 2017 | 06:17 PM
5th Gear
Okay. I am in NY which is probably on the expensive side when it come to labour.
Would you say labour is same as the parts?
(Realize its a bit of guess work but ust looking for ballpark estimate as to not get surprised)
thanks again!
new compressor
Old Sep 9, 2017 | 06:29 PM
No idea on the labor rates, where at in NY? If you are near Buffalo you are in lucky as Lucky8 is there and they have great prices and do good work on these as well
Old Sep 9, 2017 | 08:29 PM
abran's Avatar
Old Sep 9, 2017 | 09:00 PM
5th Gear
Thanks abran, thats amount of labour hours?
Originally Posted by abran
mx468
Dec 11, 2015 06:45 AM
cpt blakesatan
Aug 17, 2009 07:31 PM
dkinder
Oct 2, 2008 06:43 PM
tee51397
Jun 2, 2008 01:53 PM
Tris
Mar 30, 2007 03:38 PM
