crank no fire. Help pls
Old Jun 16, 2019 | 03:48 PM
G Reeves's Avatar
Default crank no fire. Help pls
I have a US spec 2006 Land Rover LR3 HSE 4.4 V8 148k miles that we had to get towed home with today. Driving along and all of sudden it was like there was not gas. Costed to the side of the road and all the light then came on the dash. The motor will crank but will not fire. I hooked up the iid tool and the only faults being B1B69-16 (2F) General Electrical Failure and B1C57-14 (2F) Passive start ignition relay coil circuit. Can any one help or point me in the right direction?
Old Jun 16, 2019 | 05:14 PM
Rufflyer's Avatar
Based upon a General Electrical Failure I would check voltage of battery, alternator output, AND ALL of the power cables, positive and negative to the battery and to the alternator and to the started. You may have not been charging your battery and simply ran it down because the alternator was not connected.
Just guessing.
Jeff
General Disclaimer: I might be wrong
Old Jun 17, 2019 | 10:13 AM
abran's Avatar
I’m betting fuel pump. Unfortunately on an 06’ no Schraeder valve. You need to disconnect fuel line and test pressure while cranking with tool.
Old May 29, 2023 | 08:05 PM
pkomorowski's Avatar
Any update on the resolution? Having same issue.
p8nt
Feb 11, 2014 04:48 PM
mln01
Nov 4, 2013 03:41 AM
Evan5291
Jul 26, 2011 06:06 AM
rover11
Feb 3, 2011 12:31 AM
Someszy
Dec 12, 2008 10:16 AM
