Disconnected Fuel Line?!?
Old Dec 27, 2015 | 10:18 AM
Valoblk's Avatar
3rd Gear
Default Disconnected Fuel Line?!?
After over 120,000 mostly trouble free miles, developed my first major issue with the 2006 LR3 right before Christmas. The truck would crank but wouldn't start at first, then it fired once. Detected a strong smell of gas, and then noticed that a large amount of fuel was pooling under the vehicle.
Fortunately my good friend and neighbor works in underground fuel tanks so wet were able to get the spill cleaned up.
Got under the vehicle and found that the gas feeder line leading from the fuel pump to the engine was disconnected for some reason! Reconnected the line, which seems secure, and tried to start the truck with no success. Thinking that there might be air in the line now, but can't seem to locate the Schraeder valve to bleed it.
Has this happened to anyone else? I've searched and can't find any other examples of this occurring. And does anyone have an idea where the bleed/check valve on the 4.4 is located?
Thanks in advance!
Old Dec 27, 2015 | 12:53 PM
TOM R's Avatar
Iirc remove that big cover on the engine and look at rear of fuel rail passenger side?
Old Dec 28, 2015 | 02:02 PM
Valoblk's Avatar
3rd Gear
Thanks - I'll give that a shot. There's an electrical connector striking out of the tail on that side so I'm assuming it's underneath there?
cheqbay1997
Mar 1, 2018 08:23 AM
mossmanxjt
May 18, 2012 09:15 AM
fezzr
Mar 18, 2012 12:20 AM
VCO
Oct 17, 2011 09:07 PM
aremee
Sep 30, 2006 05:47 PM
