EGR Valve - How To Clean?
Old Oct 2, 2020 | 09:50 AM
nevillusa's Avatar
Default EGR Valve - How To Clean?
Hi. I will be installing a new complete Thermostat housing assembly unit over the weekend. Because, slight Coolant leak - This unit is plastic, and has finally developed a small crack. (180,000 miles, 2008 LR3). My current Thermostat seems perfectly fine, so I'm going to keep this old one as a 'spare'. May need to slightly move the EGR Valve out of the way, to make the installation a little more easier - Provide a little more 'wiggle room'. Therefore, considering removing the EGR Valve, and clean it, as 'preventative' maintenance (never cleaned or replaced it before). Would probably use Throttle Body / Air Intake Cleaner spray? Will definitely be using new Gaskets (I believe there are 2 of them).
So here's my question - Any risk, or downside, to removing the EGR Valve and cleaning it? Any best practices? Anybody know what the torque settings are?
P.s. Will also be performing the following, since I'm already in the engine bay - Clean MAF Sensor. Remove and clean PCV valve. Remove and clean Throttle Body Intake; the metal piece with the 'flap'. Probably do a complete Coolant flush/clean/refill. If I do this, I will also probably fit a new Water Pump - I have one that I picked up a while ago, thought I would 'need' it. Will also check the various bits and pieces which run along the 2 Engine Belts, such as Idler Pulley, etc - Have done this twice before; easy job when you've done it before. Might as well also replace the plastic 'T' shaped Coolant Bleeder, which is prone to exploding - Previously put a new one in at 126,000 miles, in July 2017, but I think I'll replace it with Brass fittings - Menards is just a mile down the road. Will also clean, and re-grease, the Steering Shaft U-joint. What else would you do, or check, at the same time? I last changed Spark Plugs at 105,500 miles, June 2015. Have never checked / cleaned / replaced the Injectors.
Going on a 'wilderness' trip in a few weeks, and want to get everything in tip-top condition. Also want to get stuff done before the cold winter sets in, here in Madison, Wisconsin.
Cheers, Simon
Old Oct 2, 2020 | 12:00 PM
DakotaTravler's Avatar
You can just spray the insides with brake cleaner - with it removed of course. Its just a metal plunger/solenoid mechanism.
New gaskets indeed! They are metal but coated, at least the TB gasket is. If you re-use, I highly recommend applying a very thin amount or high temp sealant. I did so with my EGR gaskets.
If you do a flush of the cooling system, I can not recommend enough the citric acid method. I still have to do mine but bought the citric powder from Amazon. It should be great for the heater core, which it known to clog up.
https://www.bobistheoilguy.com/forum...esults.272539/
Amazon Amazon
Old Oct 2, 2020 | 01:29 PM
douglastic's Avatar
Coolant flush is on my to-do list
Thanks for that tip - I use citric acid for my espresso and coffee makers - never thought of using it as a cooling system flush - makes perfect sense!
Old Oct 3, 2020 | 03:16 AM
JUKE179r's Avatar
I’ve used oven cleaner on a friends EGR valve for his Td5 engine. Worked great.
is there possibly an option to delete/blank off the EGR valve for a LR3/Disco 3?
Old Oct 3, 2020 | 08:48 AM
You probably could but I dont see why someone would want to. With older engine this was something people did for some slight benefit, but with modern engines there is no need.
redwhitekat
May 1, 2020 02:14 PM
Vincent Goldini
Feb 17, 2020 09:56 AM
olywa
May 4, 2013 09:36 AM
Savannah Buzz
Apr 15, 2012 02:17 PM
LRD2&ME
Apr 21, 2011 10:53 AM
