Engine knock
Old Feb 12, 2017 | 12:30 PM
abran's Avatar
Default Engine knock
Since there is an engine knock thread going, I thought I would share.
Ive had 2 engines cone in with holes in them. One had a hole in the pan and would not start, the other had what the owner said started as a mild knock from low oil which turned into a major knock. It was still running before o broke it down, although loud and rough.
The first I elected to scrap without breaking down. The second I broke down and found a hole in the side of the block once I removed the motor mount bracket. 2 broken rods, one piston had been hammered by the valves.
Old Feb 12, 2017 | 01:04 PM
djkronik57's Avatar
Wow, that is carnage. I expect that's something what my old engine looked like. Safe to say that these failures are caused by low oil? The only other option in my case was hydro locking due to oil ingestion in the combustion chamber.
coors
Jan 11, 2013 09:28 PM
gtuplin
Jul 15, 2012 12:18 PM
salve7
Jan 7, 2010 02:34 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
