Few questions
Old Jan 27, 2013 | 11:53 AM
Kinz384's Avatar
Default Few questions
Just got a lr3. I'm really enjoying it.
The closest land rover dealer/shop is 2 hrs away. So was wondering if a ford dealer can do all the maintenance & checks on it ?
I need oil changed. Could do myself, but don't u have to have computer to reset car computer ? Can ford do this ?
Is it reg oil or synthetic ?
I got 2 faults showing. One is HDc system fault not available. Is it ok to do normal driving ?
& it said reduced engine performance. What's this mean ?
Thanks for info
Old Jan 27, 2013 | 05:12 PM
ghengis86's Avatar
Change the oil yourself and save some money
https://landroverforums.com/forum/sh...ad.php?t=52950
Old Jan 28, 2013 | 05:40 PM
Kinz384's Avatar
What about resetting computer?
Changing oil myself is fine. But can ford service other stuff. Or do I just set up date to travel to Dallas
Old Jan 28, 2013 | 06:01 PM
Rovin4life's Avatar
Anyone can do the maintenance. Stick with the oil land rover says. The ford store should have the filter in stock regardless of motor so it won't be that expensive. The HDC is probably an issue with the battery especially if its always at startup. You may need a new battery. Ford might have that one to. You can ask them to check your battery to see if needs replacement. The question isn't if ford can service it, its if they have the machine that can read all the codes. Depending on the year they probably can't reset the maintance light.
Old Jan 28, 2013 | 08:03 PM
Kinz384's Avatar
Ok. Yea that's what meant. If ford would have the machine. I know it's a ford motor right ?
It's a 2005. V8.
Man I hope it's just the battery. I was worried it could be something serious.
Yest I did look and notice the terminal was loose. And I put on & tightened it up. No longer says engine reduced poer Stills says HDc problem. & every few days. It'll say MSG like the parking break is on when its not
Old Jan 29, 2013 | 12:04 PM
Rovin4life's Avatar
its not a ford motor, its a land rover jag motor. The electronics are all land rover. You need a different machine to read it.
peekay
Feb 20, 2006 07:00 PM
betz470
Nov 2, 2005 10:18 PM
DiscoXD97
Jul 27, 2005 09:58 PM
srol86
Jul 15, 2005 10:37 PM
IXLR8RVR
Dec 7, 2004 02:14 PM
