Freak out here
Old Oct 14, 2018 | 09:12 AM
Dreads's Avatar
4th Gear
Default Freak out here
So, lr3 won't even try to start
Call AS A n he checked.alternator n battery at 5amp but he said battery good..
jumped it.(easy).n said to run it for 45 plus minutes.
did that in driveway then went to buy charger.
wouldn't start at Wal-Mart.
jumped.easy again.
charges for over 2 hrs and noting, zip.
stuck key in and doesn't show "ignition in key".on.dash.
mot.showjmg.fully charged so charging again.
Back story;
would occassionaly mot start but could.move cables m would start.
had oil changed and they put electric emergency brakes on.
I never use them so drive off to get kid 90 miles away.
got bad smell n couldn't fig out.
Dash started flashing, radio squealing, emergency brake light finally went on.
pushed down eng brake thong n light went.off.
got kid.n car started again nut smell came.back.
pulled.over and.utubed found manual release and that worked.
got home.and wknt start so I called AAA .
are there ignition start fuses to look for?
should or.could.i disable.my alarm sys to help.it?
it's a.new.day so should I make sure bat fully charged n hope just starts up?
should crank shaft sensor be suspect?
freaking cuz have 10yo son m have to.return today 90 miles
Old Oct 14, 2018 | 09:27 AM
Rufflyer's Avatar
What check did he do on the alternator? It may not be charging enough
Sounds like classic non charging battery with all of those warning lights. Also check the ground cable from the battery to the fender. If alternator is good, and the cable is bad, it will run until the charged battery runs down.
Let us know the outcome, it could help someone else searching the forum for the same issues
General Disclaimer: I could be wrong.
Jeff
Old Oct 14, 2018 | 09:35 AM
Dreads's Avatar
4th Gear
Ok, I'll keep u posted
Old Oct 14, 2018 | 09:37 AM
Dreads's Avatar
4th Gear
He had some handheld thing that checked alternator n battery and it printed out results
Old Oct 14, 2018 | 12:36 PM
Rufflyer's Avatar
OK. so if the alternator is good, and the battery you put in and charge it up over night is good, then the car dies after running for a while, your battery is not charging and you are draining it down while you drive.
In fact , do this:
1. Remove battery.
2. Place on charger overnight.
3. Remove ground cable lug behind where the battery mounts
4. Inspect ground cable. Look for corrosion on outside of insulation
5. Bend each inch of the cable a little and if one part of the cable is easier to bend than other parts of the cable.
6. Inspect both batter terminal and make sure e will tighten up on battery posts.
7. Coat battery posts, cable terminals, and ground terminal with dielectric grease to help insure proper electrical connection.
8 Re assemble in reverse order and see how long you can drive before it dies.
Hope this helps
Jeff
Old Oct 14, 2018 | 01:13 PM
Dreads's Avatar
4th Gear
Damn, as it were, the new AAA guy tested and.replaces battery then BAMM, works
he said.other guy prob was.trying to save me.money by telling new.to charge it n it should be good, by, that just made.me.think.and stress needlessly..thx
Anthony Rowlett
Oct 7, 2019 06:55 PM
starcraft1
Aug 15, 2019 11:29 PM
Honey Sterling
Oct 8, 2012 09:42 PM
silverfox
Oct 19, 2011 01:07 PM
SUMOSINO
Jul 20, 2009 09:10 AM
