gregs problem child
Old 09-04-2018, 01:30 PM
dorthea1's Avatar
Default gregs problem child
my lr3 2007 is showing no special programs available,I unplugged the transfer case module and plugged it back in.
tire pressure monitor fault, park is flashing
Old 09-04-2018, 02:23 PM
DavC's Avatar
Run the codes, post those here
what is your battery voltage, is the battery good? Is the alternator good?
Need more information here....
Old 09-12-2018, 02:10 PM
dorthea1's Avatar
Default peace love, and this thing is not driving but it is making me cazy
volts are fine, regulator is 13.8 14 when rpms are up . This started it read system mulfunction down high control,tire pressure monitorfail,the radio would go off flashers would go on. I changed brake light bulbs oem, brake switch,then we took it to a dealer and they told me itwas tire pressure monitor control, well they said we will start there. for a week then back to the same, then i left it out side the garage it would not even start flashers, and all kinds of codes trans faul no special programs its lowered. I unplugged the instrument cluster pluged it back in, did the same to the transfer case module, and the ECM nothing, pulled the rug up pass sidewas water after a few day it started up steal with trans faults, lower postion whats next
Old 09-12-2018, 02:47 PM
Blackngold77's Avatar
others certainly can say more, like abran, but to me that's the source of your problems. water leak in the cabin fried things on you.
1st step would be to check, and replace, the sunroof drain ends at the firewall
Old 09-12-2018, 03:06 PM
abran's Avatar
As blackngold said. Stop the ingress of water first.
Then use spell check, punctuation, and some proper grammar to help us better understand your future posts(sorry to sound like an a$$, but if we are going to take the time to respond, you can take the time to structure your posts)
You will likely be battling corrosion on the connectors in the footwell area.
I would also examine the TCCM pins and connectors for corrosion.
Rufflyer
01-21-2024 03:56 PM
Rufflyer
08-12-2019 07:45 AM
Atticus_6147
06-05-2019 03:24 PM
Fmb Choppers Fmb Choppers
10-10-2018 08:43 PM
bikercrze1
12-18-2015 08:20 AM
Quick Reply: gregs problem child
