Help with part #'s
Old Jun 30, 2019 | 05:38 PM
rsvrman's Avatar
Default Help with part #'s
Hello All,
Been trying the search function here and been searching on atlantic british, however I cant find these few parts which need to be replaced. I'm in the process of all new brakes, lower/upper control arms fluids etc. Apologize if I'm using the wrong term, but I'm trying to identify these parts with part numbers. I've tried torsion bar, stabilizer bar and sway bar I can't seem to land a result. If someone can provide part numbers or a link to each, would be grateful! On the longer bars, theres two bushings, I'm not sure if Ill replace the whole bar or just the bushing, if you can help with the right term, hopefully I can find both.
1&2 rear (Torsion?) Bar and Bushing
3 Rear (Sway Bar? linkage)
4&5 front (Torsion?) Bar and Bushing
6 Front (Sway Bar? linkage)
Thank you in advance.
Old Jun 30, 2019 | 06:02 PM
Here is your front parts
https://www.lucky8llc.com/collection...ac1-suspension
Here is your rears
Old Jun 30, 2019 | 07:01 PM
rsvrman's Avatar
Awesome! Thanks
Are the long ones torsion bars then?
Old Jun 30, 2019 | 07:31 PM
Long black bars are sway bars. Those unless snapped do not need replaced
Old Jul 1, 2019 | 10:20 AM
scoutrover13's Avatar
To add to this they are called stabilizer bars, stabilizer bar bushings and stabilizer bar links. For the front and rear. Section 204-01 and 204-02 in the workshop manual. Also a pretty helpful video at Atlantic British website.
Old Jul 1, 2019 | 02:21 PM
abran's Avatar
another part you will need...
Old Jul 1, 2019 | 05:30 PM
rsvrman's Avatar
This isn't rust just a little patina!
I plan to coat with fluid film after install. It looks bad, but nothing is rotting away. I lived in MN most of my life, so comparatively this is nothing. My expedition that was 10 years old, I could push my finger through the frame, and the floor.
Alex_M
Aug 26, 2021 09:03 PM
Roverup
Sep 9, 2019 03:38 AM
coors
Apr 1, 2018 08:56 PM
Smith CH
Mar 10, 2015 08:24 PM
texci77
Mar 30, 2012 09:40 AM
