Lean Codes and PCV Issue
Old Feb 11, 2017 | 10:52 AM
LR Techniker's Avatar
Is this with a new MAF or old MAF?
Old Feb 16, 2017 | 02:33 PM
TexasRover1's Avatar
LR Techniker, sorry for the late reply. I installed a new MAF but it was not the cause of my lean codes. I had the lean codes for a while, one attempt the Indy shop made was to clean the MAF sensor and it seems like that killed the MAF cause afterwards I was getting both lean and rich codes.
I installed a new MAF sensor and got rid of the rich codes. The CEL was still on due to the lean codes. Once I finally reset the adaptations the lean codes have not come back either.
I believe this all started when the dipstick went missing after an oil change. I did not locate and install a new dipstick for a few weeks and it seems like the PCV system was sucking air through the dipstick tube, the computer was trying to compensate for this, later I installed a new dipstick but the computer did not automatically adjust back. Resetting the adaptations was necessary. Like you mentioned! Thanks!
Old Feb 16, 2017 | 07:02 PM
EastCoast's Avatar
Kind of a highjack but when I was cleaning my Landy of snow from our most recent dump, I noticed the air intake was pretty well blocked with snow. As the vent is on the passenger side and not looked at every time we drive, how significant a difference would a blocked or even a partially blocked air intake vent have on MAF readings and throwing codes?
Old Apr 30, 2021 | 11:29 PM
VI LR3's Avatar
Default Same issue
thanks for the info. I have been scratching my head about this. I’ve got the battery disconnected and switches the PCV and the maf. I’ll try in the morning and see if a hard reset is all I needed
Phatrowles
Sep 22, 2013 12:28 AM
D2
Jan 19, 2009 05:01 PM
jkid
Sep 29, 2008 08:15 PM
2000 Disco 2 SD7
May 3, 2008 07:10 PM
trevorr
Nov 15, 2007 08:29 AM
