LR3 A/C making a humming noise
Old Oct 7, 2016 | 03:19 PM
  #41
djkronik57's Avatar
Originally Posted by cmb6s
I have to wonder if the groaning that people are talking about is the result of low refrigerant or perhaps moisture in the system. When a system is recharged, the shop SHOULD evacuate the entire system and refill it from zero. That would also draw out any residual moisture that has accumulated in the system. Just a thought...
Could be, but how would moisture get in without a leak, unless it was there from the factory?
Yeah the rear AC lines for the LR3 are apparently a problem point as well, from what I hear. Some people just choose to block them off when they start to leak.
Old Oct 7, 2016 | 04:40 PM
  #42
Coleroad's Avatar
If the system isn't leaking. That groan is most likely the clutch bearing. That also explains the noise going away when the ac compressor clutch unlocks. Eventually it will seize up, or the movement on the shaft cause the compressor to leak. Just my thoughts
Old Oct 7, 2016 | 06:07 PM
  #43
djkronik57's Avatar
Our compressors do not have clutches, they are a variable displacement clutchless design.
Old Oct 10, 2016 | 09:17 AM
  #44
EstorilM's Avatar
Really cool, not sure how I missed this as I know every worthless dorky fact about all of these vehicles - but that's a new one. I guess the system has generally worked well for me so I didn't care.
But yeah it's smart, it just varies the output with solenoid valves depending on the line pressure reported to the computers.
Totally blows my mind how ahead of the game they were in 2004.
I really need to do a fresh recovery / recharge on mine now, just to make sure it's running 110%. I guess I'll still need it for defrost in the fall / spring.
j.dstasio
Nov 19, 2010 03:36 PM
Jerover
Jun 2, 2009 05:05 PM
carnut
May 7, 2009 10:32 PM
carnut
Jan 21, 2009 08:52 PM
carnut
Jan 8, 2009 08:25 PM
