LR3 Check Engine Light
Old Jun 6, 2018 | 06:00 AM
jbullock78's Avatar
Default LR3 Check Engine Light
Hello!
I wanted to get some feedback on a check engine light. I reciently bought a 2006 LR3 with 142k miles from a private party, replacing my 6 week old LR3 that was deemed a total loss 2 weeks ago by the ins co. :-(
Everything runs fine, he kept up with maintenance and has records. He replaced many things etc. I am new to LR3s and have just been reading/researching before purchase on these forums.
I had planned on getting the 150k service done at next oil change in 3k milles. Should I take it in sooner?
Any input would be great.
James
Old Jun 6, 2018 | 01:42 PM
schwaggy's Avatar
You should get at the very least a cheap OBD scanner or have the codes read by an auto parts store so we know what problem code the light is indicating. Or spring now for the holy grail of diagnostic tools, the GAP Diagnostics IID tool. It will pay for itself many times over so don't be put off by the price.
Old Jun 7, 2018 | 05:59 AM
jbullock78's Avatar
Default Check Engine Light Code is P0128
Hello-
So I got the code read and it is P0128 which is Coolant Temp Below Thermostat Regulating Temperature. Anyone have experience with this?
Old Jun 7, 2018 | 08:46 AM
abran's Avatar
Change out your thermostat assembly/water crossover.
Either your temp sensor is no good or your t stat is stuck open. That single part has both of those components so it should fix the issue.
Old Jun 7, 2018 | 09:29 AM
jbullock78's Avatar
Excellent- Will do-
Thanks!!
dev99disco
Oct 13, 2019 07:42 PM
DSMITH86
Oct 12, 2018 05:42 PM
ToiletDuck
Oct 7, 2018 10:48 AM
KJoii
Jun 11, 2015 09:47 AM
shoei_1411
Nov 29, 2010 07:57 PM
