LR3 Coolant Bleeding, expansion tank question
Old Oct 24, 2022 | 07:48 PM
DakotaTravler's Avatar
Default LR3 Coolant Bleeding, expansion tank question
Everything seems good. Heat inside, etc. But neighbor says top of expansion tank should have fluid in it. His does and so did my old one. That weird area on the very top. But this is also a newer style tank. And we did manage to get fluid up there and fill the area by opening the black breather cap on the tank, but then it seems to have emptied out while I was tinkering on other truck projects. Tank itself is above the hot line, so still plenty of coolant.
Old Oct 25, 2022 | 09:42 AM
tracyc's Avatar
Mine is a 2008, with a recently replaced resorvoir. It does have a bit of coolant in that top section where the overflow hose enters. Pic below taken when cold:
Old Oct 25, 2022 | 04:22 PM
Yeah, I think I will bleed mine more. On anther note, I am pretty sure you have the wrong coolant expansion cap on there. The 4.4 should have 110 kPa/16psi. Yours appears to be for a different Rover which operates at much higher pressures - about 30psi.
Old Oct 25, 2022 | 11:35 PM
ZGphoto69's Avatar
Definitely should have coolant where the return line joins the tank. Try running it for a while, release the bleeder screw and loosen the cap and watch the fluid level... Add more coolant as necessary. Also, squeezing the big hose going into the thermostat housing to get things moving can help some. I also found that disconnecting this hose at the thermo housing and pouring coolant directly into it until full, can speed up the bleeding process dramatically.
Old Oct 26, 2022 | 03:04 PM
tracyc's Avatar
I suspect/hope that's the label that off brand manufacturer slaps on everything. I could certainly be wrong, but no problems with it after 1 year.
Old Oct 26, 2022 | 06:52 PM
No, because that cap is a different part number. Even the genuine caps look like that, different part numbers based on ratings.
Old Oct 26, 2022 | 10:40 PM
tracyc's Avatar
Ah, I see. I guess I'll need to get the correct one. Thanks for the heads up!
Wheelspin
Aug 12, 2020 12:02 PM
gillart
Jan 22, 2015 03:35 PM
aguison
Nov 16, 2012 09:29 AM
Discobeth
Apr 29, 2012 07:48 AM
brooksa
Jan 17, 2009 03:09 PM
