LR3 Front Tire Wear
Old Sep 28, 2016 | 04:07 PM
waytoomanycars's Avatar
5th Gear
Default LR3 Front Tire Wear
I have a 2005 with 163k. The front tires have very heavy wear on the inside. The wear is very smooth, so not indicating a ball joint. I am also experiencing a wandering steering going down the road, especially on rougher roads. There is not any clunking from the suspension.
What could cause the tire wear and steering wandering? I am in the middle of no-where, so finding a shop that can do anything on the LR3 is nearly impossible. I will have to do most things myself.
Let me know what you think. I appreciate any help.
Old Sep 28, 2016 | 06:31 PM
DavC's Avatar
When was the last time you had an allignment done? Bad suspension calibration can affect how the EAS sits and cause some tire wear issues.
Could be wheel bearings too.
Old Sep 28, 2016 | 06:56 PM
5th Gear
I have never had an alignment completed. Bought it at 120k a couple years ago. I know these are very sensitive to do an alignment on.
Old Sep 29, 2016 | 09:52 AM
Jagfixer's Avatar
Alignment and check bushings. Are you rotating tires at same intervals?
Old Sep 29, 2016 | 02:59 PM
5th Gear
Tires are rotated roughly every 5k miles. Is there an easy way to check the bushings? Everything I have read is indicating a clunk type of sound at slow speeds into a driveway.
Old Sep 29, 2016 | 03:37 PM
DavC's Avatar
Definitely get an alignment done... Dealer can do a precision alignment or if you have a GAP tool you can set it to precision mode and have anyone do it.
that alone would explain tire wear
Old Sep 29, 2016 | 09:00 PM
jpc1818's Avatar
You are going to need to replace all of the suspension bushings. Atlantic British sells a kit. I did it on my LR3 a few years back. Not the easiest, but did it all myself in the driveway and it made a world of difference. Research it here and everywhere you can. Hope that helps. If you do buy the kit, lmk before hand. I need the rears and they only sell it in a complete (F&R) kit. I would buy the rears off you..
Old Oct 4, 2016 | 08:55 AM
clarkritchie's Avatar
Don't get an alignment until you check your bushings, as they are probably shot. I wasted money on an alignment after adding Johnson Rods as the alignment shop didn't bother to tell me my bushings were wasted (which was very evident when my LR place pointed it out a few weeks later during an oil change). I'm having my bushings replaced tomorrow and will be spending another $80 for a 2nd alignment (but at a different alignment place!).
Old Oct 4, 2016 | 09:27 AM
Coleroad's Avatar
Yep when that rear lower bush wears out. The front toes out when going down the road. It doesn't have to be to the point of clunking to cause enough toe out to wear the tires.
Old Oct 7, 2016 | 01:30 PM
I didn't have the clunking but my bushings were visibly worn out. Got new poly bushings the other day and holy-moly it drives like a new truck now.
RITTER
Aug 24, 2012 03:16 PM
rphotographer
Mar 30, 2010 04:29 PM
lipadj46
May 24, 2009 09:04 AM
SpeedAgent
Jul 12, 2007 11:03 AM
Mikek2s
Dec 1, 2006 06:34 PM
