LR3 Replaced Valve Body Solenoids......Won't Start!!!
Old Jan 1, 2020 | 04:10 AM
enb54's Avatar
What a pain! Glad I could sorta guide you into the right direction but you ultimately found the issue. I was hoping it was an external adjustment. But, you found the problem and got it done. I am sure this will help others in the future.
X3+, Always great to see a resolution published! Thanks for the detailed explanation!
Old Mar 11, 2021 | 02:26 PM
Marcus30d's Avatar
Default Same issue
How did you fix the issue where the replacement solenoids defective?
Old Jun 10, 2021 | 02:00 PM
scorpion's Avatar
Thanks so much for posting this fix.
I am close to swapping out the solenoids and this is a great reminder to pay attention to the instructions to the T.
Removing the value body makes me a bit nervous.
This trans is also used in some BMWs and there are some detailed videos on YouTube on the process.
Old Feb 9, 2023 | 07:35 AM
StaxxBundles1's Avatar
Default Range Rover sport hse 2008
I replaced valve solenoids and did the whole procedure n now I don’t have PRND on the display . Is there any way I could have put the valve sleeve in upside down or does it only fit one way or can it be installed wrong?
Old Feb 9, 2023 | 06:10 PM
loanrangie's Avatar
You likely didn't engage the lever into the slider correctly.
Old Feb 9, 2023 | 07:20 PM
SeattleDriver's Avatar
I noticed that the dash indicated that the car was in D, but the shifter was still in park.....? I could not get the car to shift either out of park, and turning the key did nothing for me. The big fat error code of E was gone, but the car would not crank. I implemented the gear shift manual shifter through the side of the shifter and was able to slide the shifter through the gears. I went up and down the shifter column about three times, and stopped at N (nuetral) and wallah, I saw the "D" disappear from the dash, and feverishly began to turn the key........Virrrrrooooommm!! I am in business
So I had this precise problem a few months back. In my case a grounding wire in the TCM plug was loose, 99% a flaw from the factory and when I serviced my transmission the connection became worse. My TCM was getting an intermittent ground which caused a transmission fault and later the shift lever to be out of sync with the position sensor. So when I tried to start the car it would not start. Eventually we noticed the 4x4 info screen showed the car in N or D while the dash showed Park. Once I used the Park bypass (thinking it would need to be towed) and shifted to N, I was able to start the car and drive home.
It took me a long time (and a lot of help) to find the issue, but it was a relatively simple fix. I didn’t have the right tools to repin the connector so I sent it to a LR mechanic who had seen similar issues before.
yockstar
Dec 29, 2019 08:38 PM
Ron6977
Feb 22, 2013 12:29 PM
hilltoppersx
May 25, 2011 08:11 AM
grandkodiak
Apr 2, 2011 10:56 AM
tiredone
Feb 23, 2009 12:12 AM
