LR3 Woes
Old Nov 13, 2018 | 09:23 AM
abran's Avatar
I guess my point is the oil light and rattle sound more linked together mechanically.
low oil pressure and prolonged oil changes can create the rattle on the chains. If it starts to get worse, you will need to address it. If it jumps timing the motor is done.
Old May 22, 2019 | 03:18 PM
DillJLoc's Avatar
Broken Throttle Body harness... Land Rover quoted me $4k to install new harness. I bought $5 zip tie set and fixed it. Saved myself $3,995. Car works like a dream!
Old May 22, 2019 | 07:35 PM
If you think about it you probably saved closer to 3999.92 as you probably have a ton of zip ties for later use. Good job!
Old May 22, 2019 | 07:45 PM
DakotaTravler's Avatar
Or if you have a bag of 20 zip ties and one each can fix $4k worth of issues, then that $5 bag of ties has the repair power of $80,000.00!
Old May 22, 2019 | 08:52 PM
DillJLoc's Avatar
Haha! For sure. I’m guessing Land Rover didn’t wanna save a customer money with the mention of...gasp..zip ties 😂
Old May 23, 2019 | 08:25 AM
abran's Avatar
Nice, I’ve had that one come up more than once. Supposedly the connector can be bought on Amazon, it’s used on other vehicles, problem is pushing out all those pins!
Old May 23, 2019 | 08:34 AM
DillJLoc's Avatar
Agree. I bought another wiring harness, but used for $60. Just need to get it fitted. In the meantime my zip tie situation will work.
devildollnyc
Dec 25, 2018 05:12 PM
vALEXv
Jul 3, 2012 09:21 PM
tacker
Jul 10, 2010 09:36 PM
DanR
Jun 27, 2009 02:11 PM
bribake
May 6, 2007 03:51 PM
