messsge Special programs not available
Old Jan 2, 2019 | 11:21 AM
  #31
K600mel's Avatar
Default Program unavailable
Originally Posted by Viking1
special programs not available Land Rover mech says it’s throwing a code pointing to the all terrain module under the center console
hi we having the same trouble as you do you have any ideas what to do it’s drivng me nuts😏
Old Jan 2, 2019 | 03:56 PM
  #32
Viking1's Avatar
LR tech replaced the transfer case module it’s located on the firewall behind the battery however he also ran a new ground from the transfer case module to ground I have a gut feeling this was the problem all along
Hope this helps
Old Jan 26, 2022 | 02:29 PM
  #33
Luisfe's Avatar
Do you have an idea how to overlay the wire for the ground ? I just check my tc module and i opened it up, i examined carefully it is clean no burns or tart or corrosion. I am trying to follow your advise viking1 that the problem could be only in getting a new ground. But i have no idea how to do that. Sorry for my ignorance.
Old Jan 26, 2022 | 03:44 PM
  #34
Viking1's Avatar
Default all terrain control dead
This problem for my LR3 was resolved by a Land Rover Tech.But not before some trial and error. First they told me it was a bad console control. it proved not to be the case as he had a spare which did the same thing. he ended up resolving the issue by running a separate ground from the transfer case module on the left side of the fire wall to a grounding post nearby. Its been good ever since. a preventable note never leave your skylight open during a rainstorm you will come back to a real mess and tough clean up and some down the road corrosion issues such as malfunctioning terrain controls.
Ohhayholly
Jan 12, 2019 09:32 PM
Satee John
Feb 28, 2018 05:19 AM
jaystekan
Nov 10, 2014 11:06 PM
Randy P
Jan 3, 2009 09:30 AM
